touch screen prob
Discussion in 'Nintendo Forums' started by firepig, Jan 16, 2008.
  1. firepig
    firepig
    Jun 8, 2006
    69
    +4
    hi the touch screen on my sons DS lite takes about 3-4 mins to start working from when it's first turned on is this normal ?:cool:
  2. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    NO
    it should work right away
  3. firepig
    firepig
    Jun 8, 2006
    69
    +4
    The DS was bought in USA at Christmas as a present how does the warranty stand and any idea who i contact
  4. Mike45450
    Mike45450
    Feb 5, 2006
    179
    +14
    I hear the touch screen needs to be calibrated for use. Have you tried that?
  5. Flashy
    Flashy
    Apr 20, 2006
    3,310
    +1,145
    When you say it takes a while to start working, what do you mean, exactly? Does the screen have power (is it lit up), or is it that it doesn't respond to touch?
  6. firepig
    firepig
    Jun 8, 2006
    69
    +4
    the screen works fine using the direction pad and the A,B,X,Y buttons straight away it just takes a while for the screen to pick up stylus inputs
  7. Flashy
    Flashy
    Apr 20, 2006
    3,310
    +1,145
    Neither would have been normal, I just wondered which sort of "wrong" it was. In short, no, the touch screen should respond from the moment the initial health and safety screen, which even says "touch screen to continue" appears. Is it still in warranty?
  8. firepig
    firepig
    Jun 8, 2006
    69
    +4
    Yes it was bought in late Nov early DEC 07 from New York by a friend as a Christmas present for my son
  9. Flashy
    Flashy
    Apr 20, 2006
    3,310
    +1,145
    This in a post from the most recent broken hinge thread:
    I'd give Nintendo UK a ring and see what they say. Sounds like they're pretty sympathetic to things going wrong.
  10. firepig
    firepig
    Jun 8, 2006
    69
    +4
    Thanks will give them a call cheers :smashin:
