Touch Screen jukebox software
Discussion in 'Home Entertainment Computers' started by MrHyde1969, Jan 7, 2012.
  1. MrHyde1969
    MrHyde1969
    Jul 31, 2005
    506
    +19
    Hey guys,
    Hope this is the right place for this. I am looking for a piece of software that can use to replace my current setup. I am running THE PCJUKEBOX(which is an amazing piece of software but will not run under win7 as is showing its age a little bit now), it is also no longer supported. I want ease of use and quality playback of all types of music formats. There are a few that I have found but they all seem 'busy' with too much stuff going on.
    Anyone out there that has a jukebox setup and can share what they are using with me :D
    If you visit the pcjukebox website and have a look and the software, it will give you an idea of what i am looking for. :thumbsup:
  2. sirlayabout
    sirlayabout
    Apr 11, 2010
    2,091
    48
    +97
    have you thought about windows 7 media centre, with the right codecs that can work easily. Has a great interface for either a remote or touch screen (have used both myself). I recomend the k lite codec pack. One simple install and all the major file types get covered.
    - Aaron
  3. robbo100
    robbo100
    Dec 25, 2005
    1,481
    83
    +269
    JRiver is supposed to work well as a music Jukebox.
    I have never used it.
    Most HTPC software will do the job, but it might be far more than you are looking for.
  4. nacmacfeegle
    nacmacfeegle
    May 1, 2008
    3,719
    Auchenblae
    +1,488
    Try Logitech Media Centre previously known as Squeezebox server, use it with squeezeplay and you could add a smartphone into the mix. There's a couple of really good apps about for android and iOS.
    It's free and specifically designed for music only, there may be a few touch screen skins still around for it.
    If you are on windows, Moose makes a nice front end, but it's a while since I looked at using a large touchscreen, as I use phones and pads on my set up.
  5. mjn
    mjn
    May 24, 2001
    23,486
    Herts, England
    +11,875
    Wmc7 is very poor for music.
    Have a look at ultimate jukebox, should do all you require.
  6. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
