Touch Screen Frame-metal interference?!?
Discussion in 'Home Cinema Building DIY' started by Rollin, Oct 30, 2003.
  1. Rollin
    Rollin
    I have had a Sanyo touchscreen installed in my wall to operate a PC juke box. I removed the old plastic frame surround so that I could use an aluminium frame I had made in Germany. The frame looks great but interferes with the operation of the screen. The screen is capacititive touch enabled and I'm assuming it's the fact that the frame is metal that is causing the problem. Anything I can do to get round this? Would "earthing" the frame through the screen chassis help?
  2. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    Can you put a bit of insulation tape around the inside of the frame to isolate it?
  3. Rollin
    Rollin
    I tried that and unfortunately it didn't work.
  4. Bluey
    Bluey
    Just wondering where you got the touchscreen from
    as I am thinking of doing a similar project and would be interested to know some details about the system you installed in general ie' hardware /software you used :)
  5. Rollin
    Rollin
    Managed to get the screen from Ebay for £200. I think they retailed at about £900 at the time. The software is a heavily reskinned (and still not finished) version of Musicmatch.
  6. Rollin
    Rollin
    The other hardware is an old PC tower which is hidden in the wall. It's only a P350 but is plenty for this application. The soundcard is a Yamaha SW1000XG (slight overkill). This feeds a stereo amp (also hidden). Speakers are Kef Eggs
  7. Bluey
    Bluey
    Have you looked at "Music lobby" www.cinemaronline.com
    Their software looks like it does the job very nicely.
    Bluey:)
