Total novice requires help
Discussion in 'Home Cinema Speakers' started by Devil On Your S, May 24, 2004.
  1. Devil On Your S
    Devil On Your S
    May 24, 2004
    1,649
    Lincoln
    +153
    I'm this week upgrading my television and adding a 5 speaker setup to my DVD player. I've plumped for this one here :-
    Yamaha TSS10
    My DVD player is only a cheap one, but It's always been pretty good for me :-
    SamsungS224
    The questions I'm asking are about the Yamaha setup, any advice on that, and if I need anything else. I'm assuming it will be compatable with the DVD player and I won't need any equipment?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The unit should be compatable with your dvd player and the only additional equipment that you will need will be connectors and cabling. I don't know whether speaker cable comes with the setup but if it does you will still need either a coaxial or optical cable to connect the DVD player to the Yamaha unit
