Total Novice PW7 question
Discussion in 'Plasma TVs Forum' started by ucsman, Dec 21, 2004.
  1. ucsman
    ucsman
    Nov 25, 2004
    22
    I am considering taking the plunge for a 42" PW7 monitor to complement the rest of my (unfortunately) simplistic AV gear (Sky + and Sony DAVS 888 DVD/AV system). I plan to forego the usual RF input and take the feed straight from SKY+, optical cable and RGB scart into the DAVS888 and have a feed (component) from the monitor to the television (or perhaps via an RGB>VGA interface).
    Checked out the advice for newbies thread - just getting my head round it all (sounds like some of you guys could work for NASA!)
    Would like to upgrade my kit when time and fundamentally, money allows, though saddled with this kit for now.
    Any connecctional advice much appreciated, and keep up the great responses on the forum - always hope for us less well endowed with AV-focussed brain matter. :confused:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    SKY+ RGB>VGA and DAV via component will work very well mate.....
  3. ucsman
    ucsman
    Nov 25, 2004
    22
    Thanks for the advice hornydragon.
    From your expert eye, is there any potential issues with lip-sych on the PW& when used with Sky+ and anything that I could do to avoid this flat-screen issue.
    Many thanks again
  4. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    ucsman
    i basically have the same system.......but with normal sky...........no noticeable lip-sych problems that i'm aware of.
    cheers,tam
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Lip sync is an issue but the is a devoce Felston i think that works by adding delay to optical sources..
  6. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    sorry..........couldn't quite understand that................are you saying there is a device you can buy that rectifies any lip-synch issues?
    cheers, tam
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    YES made by a company called Felston http://www.felston.com/ £192 tho...... or get an Iscan HD which does the same and so much more...
  8. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    hasn't ben an issue for me.............so at £192 'll leave it.................hope i don't start noticing it though!
