Total Newbie.
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by SimonG, Mar 6, 2003.
  1. SimonG
    SimonG
    I have the requiremnt of capturing a bit of holiday footage and occassional use. My PC has a 2GB hard disk, so unlikely I would want to do anything fancy, there is always the chance I'll never use this again. Real point & shoot stuff.
    QVC have this today
    http://www.qvcuk.com/ukgasp/framese...ts/Search.dll&search=1&frames=y&Criteria=hi-8
    which made my partner think of getting one. Off on holiday in ten days time. Budget £200-£250 to inlude any accessories that are essential.
    Cheers for any help.
  2. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    A quick check on pricerunner shows the best price being £259 so the price for what it is looks okay but you will need to spend quite a bit more if you want to get the video onto your PC as this is not a digital camcorder. You will need a TV capture card (or similar) to do this.
    If you really want to connect to your PC then a Mini DV camcorder is the way to go. Looking on Pricerunner again shows the cheapest to be a JVC at £333 (see here for the full list http://uk.pricerunner.com/sound-and-vision/vision/camcorders/browse?sort=5&a_304=Mini+DV )
