Total newbie looking for wall mounting help
claire
Hi there, i dont want to be drilling into walls or anything (im a 17 year old girl live with dad who doesnt keep to well) and i was hoping that i could get a bracket were you fix the bracket to the wall then fix tv to bracket with little to no hassle is this possible in anyway, or could anyone reccomend any other methods ?
Member252055
With all wall brackets you fix a wall plate to the wall, fix the other part of the bracket to the TV, then hang the TV on the wall bracket. It's a really simple installation but in all cases you do have to drill the walls to fix the wall plate.
Your other option is some kind of pedestal floorstand which would invlove some assembly but no wall drilling.
What sized TV do you have and where are you hoping to install it?
Regards
Graham
claire
Hi there thanks for the info, its a 26" bush one and im hoping to install it on a wall that is my room then other side upstairs hall.
