kmark40
Having changed everything in my original build, apart from the mobo and RAM. I thought it prudent that I just start my build thread afresh. So here we go..
Original thread
Current config
Hardware
Software
The catalyst for the recent changes was me attempting to update the BIOS on my mobo. This resulted in an unbootable machine, with all of my data on it. After many tests, I gave up the ghost, retrieved most of my data, using an application called getdataback and reformatted the HDD. After reformatting, I created 3 x separate partions. 1 - Vista 32bit, 2 - Windows 7 RC 64bit, 3 - Data (movies, music etc). I kept the vista partition, as I wasn't sure whether I would like Windows 7.
I do have to say that I'm impressed with w7 so far. I don't know whether it's because it's a clean install with partitions, but there's been absolutely no disk thrashing. It's very slick and hugely user friendly.
The aim is to keep the system as streamlined as possible, though windows 7 seems a lot less resource hungry than vista.
Mediaportal and kmplayer all still work good under W7, but I am still experimenting with W7 Media Center and the tuning aspect, to give me an all in one solution. I will expand further, but the main problems were explored and dealt with in the following threads.
DVB-T Decoder error
DVDViewer not finding all channnels
Massive thanks to Davey Bryce for build inspiration and help with 7MC. I'm sure, I'll be calling on him again soon.
More updates when I am near done.
Original thread
Current config
Hardware
- Black Silverstone LC17B HTPC case – Brilliantly laid out, with loads of HDD bays
- Gigabyte GA-MA790X-UD3P Socket AM2+ ATX Motherboard – changed my original 780G board to this in order to keep costs down and utilise my 4GB of DDR2 RAM.
- AMD Phenom II X2 550 CPU (Now a II X4 B50) –AM3 CPU. Have unlocked both of the dormant cores using a BIOS to make it quad core.
- Scythe Mini Ninja Heatsink – can be used passively. Though I have replaced the fan with a noctua fan.
- OCZ ModXStream Pro 600w - Modular PSU to help keep cables tidy and aid airflow.
- 2 x Samsung SpinPoint F1 HD103UJ 1TB Hard Drive - One drive is master and has all of the OS on it. The other (slave), I have filled to the brim with media and have now spilled over into the master dive. By doing this, I was hoping to speed up the master drive. Not sure that this will work though.
- 2 x Corsair 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory Non-ECC Unbuffered CL4(4-4-4-12) to take system up to 4gb
- 2 x Noctua RF-8 fan – Replaced rear exhaust fans
- LG Electronics Blu-Ray & HD-DVD-Rom Combo – Superb piece of kit. Highly recommended. Watching and ripping DVD, blues and Reds.
- HIS ICEQ 4 HD 4850 Graphics card - purchased this to do some gaming and for the HD audio option. With this I am able to decode HD Audio (Dolby Digital TruHD, DTS MA etc) and output in LPCM via hdmi to my receiver. Would prefer bitstream, but this seems the best option at the moment. Gaming on this card is also excellent on my 1080p plasma. Absolutely kicks my xbox 360 all over the place.
- Pinnacle 3010ix Tuner card – Dual DVB-T tuner to receive freeview. A 7010ix without the DVB-S tuners. This was a bargain £9.99 off fleabay.
- Hauppauge WinTV Nova-S2 HD – To receive Freesat HD channels
- Pioneer 50" PDP-LX508D Plasma -
Software
- OS - Windows 7 7600 64bit (Windows 7 Home Edition on pre-order)
- ATI catalyst software and drivers 9.4 - allows me to display in Limited RGB (16-235 I think). I use the profiles in the catalyst software that comes with this to change Refresh rates using ALT +2 for 24hz; ALT +5 for 50HZ and ALT +6 for 60hz. Catalyst software and drivers are currently on version 9.9 when I last checked. Every update I have made since 9.4 has left me with really messed up blacks. I don't know what it is, or how to articulate it, I just know that all video looks a whole lot better with 9.4.
- CoreAVC 1.9.5.0 - By far my favourite video codec software. I use this to decode H.264. This version allows hardware acceleration, but only with nvidia cards.
- Slysoft AnyDVD - Allows me to watch my Bluray's without region coding and also facilitates the ripping of all of my optical discs (DVD, Blu and Hddvd) to my hard drive. Latest versions come with some sort of automatic refresh rate changer, but reports of its effectiveness are negative at the moment.
- Daemon Tools - mount the ISOs from my rips to be played
- Total MediaTheater 3 - BD, HDDVD and DVD. Have done away with powerdvd 8 and 9. I am EAGERLY awaiting the release of Slyplayer from Slysoft.
- KMPlayer 1434 - will play everything you throw at it.
- imgburner - creates iso's
- mediaportal 1.02 with streamedmp 08.448 (superb frontend. all media, other than hddvd and bluray discs are accessed through this). Still experimenting with this new version of mediaportal. It includes an automatic refreshrate changer. More info on MP here or Theydon Bois' excellent build thread Theydons HTPC and PC upgrade Project
- Haali MKV splitter – I am using a 64bit beta from here
- MakeMKV – I use this to archive my DVD and Blurays. It is very good and relatively quick, though it will not archive HDDVDs, which is mighty frustrating.
DVB-T Decoder error
