I bought an digital optical (toslink) cable to connect my Sky+ to my new Philips HTS5700R DVDR home cinema BUT although the connector fits into the Sky+ box, it does seem a bit loose, the other end if too bid to fit into the Philips unit. I take it that Toslink cable connections are not 'standard'?????
Can anyone suggest a cable that has a smaller connector at the 'other end'?
Thanks,
Thanks,
