TOSLINK OR COAX OVER 12-14m ?
Discussion in 'AV Receivers & Amplifiers' started by chris l., Nov 12, 2003.
  1. chris l.
    chris l.
    Mar 31, 2002
    270
    +3
    My system will shortly consist of:
    Sanyo Z2 projector and Samsung HD935 DVI dvd player (decided to keep the 935 nearer to the Z2 to keep the DVI cable length acceptable).
    Denon DVD2200 feeding (NTSC / PAL Progressive to a Panasonic TX36PD30 and component to Z2
    Both 2200 and 935 will need to feed digital audio to my Denon 3802 (has 2 optical and 1 coaxial in)
    From the 935 is will be a circa 10m feed and from the 2200 it will be a max 1m feed.
    What is the best way to feed the signals to the amp ?
    I'm thinking 10m coax from 935 and 1m optical from 2200.
    Is their any rules of thumb on max lengths for optical toslink / coax cables.
    Thanks in advance.
    Regards
    Chris L.
    :confused:
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I think that the rule would be that a long cable is probably best as an optical BUT it needs to be a good optical which probably means that the cost will be frankly enormous. So for the minute difference, it is probably better to get a long coax at a fraction of the price.
    So your 10m coax and 1m optical sounds pretty reasonable t me.
    Ad
  3. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
  4. Ruu
    Ruu
    I'll get flamed, I know I will, but I have thick skin so who cares. I too had more or less this exact decision. I needed to connect my PC (with coax and optical outs) to my receiver across a room, which requires roughly 25 feet of cable. Originally the PC was next to the receiver, so I used a reasonable quality 1m monster optical cable - sounded really good to my ears. Then the room got re-arranged when I got my projector so that the sound was oriented the same direction for both PC and HT use. In my desparation to get the thing connected (while I figured out what to do with either a decent coax or long optical cable), I wandered over to ye olde Radio Shacke and purchased myself a 24foot composite video cable for the princely sum of $5. I guess Im blessed with insensitive ears, but I can't tell the difference, and for the non audiophiles out there it might be worth dropping 5 dollars to see whether you can too.
    Dave
  5. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    Electrical cable is normally better than toslink, but over distance the advantage swings back to optical. Try a reasonable priced optical, and if that's a no go get a long co-ax and cross fingers!!
    Mind you with digital cable it's all a big con anyway!! See HI-FI choice issue 239. Canford Audio did an experiment using wet string to transfer digital signals from a CD player to DAC. It worked, and with no audible degradation!! Oops!!!! :D
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    It needs to be a salt solution and the certainly didn't say the was NO AUDIBLE DEGREDATION but yes it does work, mind you so do coat hangers :)
    at the distances you are talking about dececnt quality cable should have no problems with accurate transmission of data. I am sure I have seen 30m TOSLINK. Get the basics right and these signals can go long distances, SDI as well
  7. gunrock
    gunrock
    Apr 3, 2003
    132
    The Burbs, London, UK
    Anecdotal, maybe:
    I've got an 11m digital co-ax linking up my DVD player to my amp. Whilst I haven't tried optical, it seems all good to me, and my amp doesn't stutter or dropout when I'm listening to music or watching movies.
    Gunrock
  8. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Make sure to use a 75 Ohm coax only (if you choose coax).
