TOSLink Optical splitter
Discussion in 'AV Receivers & Amplifiers' started by OutKast, Apr 3, 2002.
  1. OutKast
    OutKast
    Does anyone know where (in the UK) I can get a Optical splitter so that my amp (which only has one input) can be split so that I can input 2 peices of equipment?
    I have read things about them and seen some pics but cant seem to find anywhere that does them. How much do you think it might set me back??
    Cheers,
    OutKast
  2. Taz
    Taz
    Sorry Mate cant help you, but im looking for one as well!;)
    Taz.:cool:
  3. MoonsSpawn
    MoonsSpawn
  4. Fartpants
    Fartpants
  5. OutKast
    OutKast
    Ok Guys,
    Thanks for the recommendations, but the type of splitter I am looking for is a bit cheaper - a bit like this -->>> here
    Unfortunately you have to buy a minimum of 20 units to order from this company! (so thats no good) - unfortunately its the only place i have found that do them! - Anyone else know where i could possibly get one of these??
    Regards,
    OutKast
  6. Fartpants
    Fartpants
    Try homebase or B&Q I've seen 'em there
  7. tk2001
    tk2001
    Nov 4, 2001
    1,402
    48
    +36
    B&Q sells the exact one on your link for around £10 give or take 1 or 2 pounds - I should know, I work there!
  8. OutKast
    OutKast
    Thanks for the info 'fartpants' and 'tk2001' - I went and picked one up today - now all I gotta do is wait for my amp to arrive....Cheers guys for your help!!:D
  9. sanjay
    sanjay
    Optical splitter you're looking for can be purchased from
    www.cablelogic.co.uk.
    They do not show it on their site but when I bought my optical cable I just happened to ask them and they had stock of these.
    They cost me £ 10.00 + 2.99 P/P. Cheap at the price and useful
    too.
    try sending them e-mail from their site. Good luck
  10. OutKast
    OutKast
    Cheers for the link sanjay, but I managed to get one from Homebase in the end for £4.50.
    Regards
