Question TOSLink Optical Out 192Khz or 96Khz
bwfc0907
I am buying a TOSLink 3 way switch for
Sky
PS4 Pro
Laptop
They are are all so I can get DTS as my receiver doesn't support 4K so need the source for picture direct to TV and TOSLink to switch connected to the receiver. My receiver only supports ARC 2.0.
Do I need a switch that supports 192Khz or 96Khz?
Any good links?
ChuckMountain
What TV have you got ? Some newer ones support DTS etc over ARC now. This was a limitation of the TV rather than the amp. You could then plug your sources into your TV and then use ARC to hear them.
Assume you have Sky Q as otherwise just route through the amp.
What's wrong with the laptop display? Have you made sure it is 1920x1080 output ? Is that the native display of the laptop?
bwfc0907
ARC on receiver only 2.0
Yes Sky Q
Laptop is 4K but suffers with tearing on TV. PS4 Pro with HDR enabled games look better so will stick to that way.
ChuckMountain
ARC supported up to 5.1 channels afaik it has done. Often you get 5.1 from the TV internal functions e.g. Netflix etc.
What they didn't do is pass 5.1 from an external device connected via HDMI.
That's been fixed in a number of new TVs so you can do it. Worth checking before you spend any more money.
Is the laptop tearing on games, if so have you locked the VSync on the games as that is the usual issue with tearing etc.
bwfc0907
I only have 1 input to my receiver for surround sound but 3 devices so will need a Toshlink Switch?
ChuckMountain
So you need to enable HDMI CEC and ARC on both the Amp and the TV. You also need to tell Sky to output DD over HDMI too as otherwise over HDMI it used to default to 2.
bwfc0907
Def did Receiver but couldn't find on tv as it has dedicated arc on HDMI connections. Did everything else?
What do you mean by 2?
bwfc0907
ARC to the amp goes into the TV out.
No sound at all on Sky or inbuilt apps. I disconnected PS4 whilst I test.
Any other thoughts?
Do I have to enable ARC for TV anywhere as can't find a setting?
What source on the Receiver do I set to get ARC sound? Will it be DVD player?
ChuckMountain
ARC can be a PITA to get working but as its Samsung both items it should work. Its also called Anynet+ I believe so check the settings under that. You might also have to physically unplug some of the kit for it to work properly the first time.
ChuckMountain
Under the sound settings on the TV you should be able to choose the sound output. Not familiar with your TV but can you select external speakers?
bwfc0907
Yeah, works with optical with 5.1 on Sky. Was hoping if can get ARC working I wouldn't need a 3 way Toshlink switch.
I'm out of ideas?
