TOSLink cable doesn't fit Toshiba TV
Discussion in 'Cables & Switches' started by andrew.g.scott, Jan 19, 2005.
  1. andrew.g.scott
    andrew.g.scott
    Jan 6, 2005
    Glasgow
    Bought a TOSLink cable (http://www.cableuniverse.co.uk/cata...ge=product_info&cPath=128_119&products_id=850) from Cable Universe. It fits fine into the DVD player but it doesn't fit our TV. We have just bought a Toshiba 32ZP38 (I think) and has a built-in Dolby Surround decoder. The audio connector is every so slightly recessed which means that the plug hits the TV casing before it clicks into place.
    Apart from cutting away the casing, I'm not quite sure what the solution might be.
    Any ideas?
  2. andrew.g.scott
    andrew.g.scott
    Jan 6, 2005
    Glasgow
  3. andrew.g.scott
    andrew.g.scott
    Jan 6, 2005
    Glasgow
