toshiba37c3030d
Discussion in 'LCD & LED LCD TVs Forum' started by leebangert, May 3, 2007.
Tags:
  1. leebangert
    leebangert
    :confused: hi all new to the forums i have a toshiba 37c3030d iam not happy with the new tv set, the blakes are grey, and when u look at the tv from the side it goes grey.its like watching a rear projection tv. can someone give me some help on how to set up the tv if any one has one, i would be very greatful otherwise its ebay for the tv, thanks for your help lee
  2. leebangert
    leebangert
  3. Analogue
    Analogue
    If you used the search facility on this forum you would have already seen that there is a very active thread with hundreds of posts on the Toshiba c3030 series .
