Toshiba zp38 series - surround out (variable) too quiet
Discussion in 'General TV Discussions Forum' started by t-c, Jul 18, 2004.
  1. t-c
    t-c
    Hi all..
    I've just connected up my 36zp38b and am trying to get the surround out (variable) output. This is meant to allow you to use an external amp to power the rear surround speakers.
    However, even with the rear speakers set to 100% in surround set up the output is so quiet that you can mainly just hear noise. If i plug the cables into the normal audio output phono's the volume is fine (but obviously not rear surround!).
    Anybody else tried to use these outputs with any success?
    Hope you can help
    tc
  2. lagrian
    lagrian
    Jul 14, 2004
    37
    I agree with you I have tried this and I have to crank the volume on my amp right up, and I mean right up. Normally if I put it this high it would blow the speakers.
  3. omez36
    omez36
    Apr 17, 2009
    3
    hi was wondering if you might be able to help, i have a TOSHIBA ZP38 SERIES TV-MODEL NUMBER-( 36ZP38B) and sometimes the picture will take abit of time to actually show once switched on, and when there is a picture it sometime jumps and flickers slighty, once its been on a little while, its fine. any ideas ? as i would like top get fixed, thanks
    Omez
  4. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    read this thread....http://www.avforums.com/forums/crt-televisions/320862-toshiba-36zp38-problem.html
    Cheers.
