Toshiba ZP18 Source Switching?
Discussion in 'General TV Discussions Forum' started by Monster, May 7, 2002.
  1. Monster
    Monster
    Oct 9, 2000
    978
    Adelaide
    +30
    I have the VCR connected to Scart 2, X-Box to Scart 1(RGB) DVD to component in.
    When I play a video the TV automatically switches to the associated input, same with the X Box but NOT the DVD.
    Is this right or should the TV also switch automatically for Component signals?
    Thanks for any replies.
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Your TV is operating correctly. There is no auto-switching on the Component (AV4) inputs. This feature is only available via Scart as it requires a small voltage sent to a specific Pin.
  3. orange
    orange
    I get the same, my DVD is using S-video.
    Pain I know, especially as it is on input 3!
  4. Monster
    Monster
    Oct 9, 2000
    978
    Adelaide
    +30
    Bugger, thats what I thought.
    I'm upgrading my amp from a Sony 940 to Denon 2802 and was wondering about using it for component switching. After helpful replies from a post in another forum I have gone off the idea but this is the final nail in the coffin. If the TV can't auto switch to component i will still have to select AV4 manually which defeats the object!!!
    Thanks chaps!
  5. Andrewp369
    Andrewp369
    I have my video connected via scart 3, but do not get an automatic switch to the video when I use it.Am I missing something?
  6. orange
    orange
    Try it on scart 2
  7. Doubledoom
    Doubledoom
    Scart 3 does autoswitch as i used to have my DVD plugged in there using S-video.
    A scart lead which is not fully wired will not send the switching signal.
