Toshiba xxWH36 RPTVs - No PAL Prog
Discussion in 'General TV Discussions Forum' started by Dimmy, Sep 12, 2003.
  1. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Not sure if this is Old News, but I just received an email from Toshiba stating that the new WH36 series of RPTVs are only NTSC progressive compatible :(
    Bummer for us!
  2. nathan_silly
    nathan_silly
    Shame. Although I guess if your collection consists of region 1 DVD's I guess it doesn't matter.
    Unless we need PAL Progressive for other sources. Does terrestrial or Freeview TV need de-interlacing?
    I'm sure I saw 625P in the user manual though!
  3. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    i thought that all proggressive stuff was done onboard a the dvd player. What does the tv have to do to accept ntscPS thats different from pal PS
    also if the dvd player has a PSconverter like the marants DV4300 would that make pal dvd's output NTSC PS
  4. acucobol
    acucobol
    Sep 7, 2003
    62
    Boo!
    I just ordered a 42wh36p 2 days ago. Does not really affect me though as I mainly buy R1.
    Is this the definitive answer, or just Toshiba saying it is not 'offically' supported?
  5. Demon
    Demon
    Dec 13, 2000
    988
    Cheltenham
    +75
    The german site states "PAL and NTSC"... I've ordered the 50wh36p.. I was happy with the 50wh18B I had, so I guess it ain't the end of the world...
  6. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Well this is simply what Toshiba said in their email. They emailed me a list of the specifications but before the list they said "The Televisions are only NTSC Progressive Compatible".
    I have no Region 1 DVDs and only a few Region Free NTSC DVDs, and generally get irrate by the 'Judder' of NTSC discs.
  7. nathan_silly
    nathan_silly
    Do you think it's worth selling my 42PW23P and buying the 42xx46B model?
    I'm sitting quite close to the set- about 2M. Scan lines aren't too bad, mainly jaggies that annoy me (occasionally), mainly shows up on Futurama slows pans/slow zooming in scenes. Judder isn't too bad either, although I guess that and the removal of scan lines if I get progressive will overall help.
    Oh I'll also order the Tosh 900E at the same time. Is the de-interlacer in it any good?
    My collection consists of purely Region 1 DVD's.
    Or do you think I should wait until HDTV's come out with DVI inputs?
  8. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Wait. What we need is a set that does 720p and that can only be a year away at most.
    You have a good set and its enough for now.
    With HDTV now definately on the visible horizon, its only a matter of time before one or other of the manufacturers produce an HDTV ready set (720p, DVI equipped).
    Hang in there mate, its difficult I know. I almost went for the new Toshibas but any set bought now will NOT give a 720p display and thats what we REALLY WANT :)
    Paul
  9. nathan_silly
    nathan_silly
    Yeah thought so. Just like another opinion whether it's worth it. It's just so annoying when you see the US RP's. DVI, two sets of component, colour correction, HTDV, coffee maker etc.
    It's a shame CRT FP are so large; I would love one but have no space. I would not consider LCD projection due to mainly heat soak problems. Although I guess if you only have it only a few hours a week it should be OK? I take it LCD PJ's are HDTV spec? PAL & NTSC Progressive? It'll certainly free up floorspace. Allowing me to have the Storm and a SVS in the space where the RP is. They are tempting.
  10. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    The internal de-interlacers on Toshiba TVs work pretty damn well anyway, and if you've a fair measure of R1 DVDs then all should bode well (I personally wouldn't be able to watch R1 DVDs in interlaced, so I don't know how you're managing now).
    And the 42xx46B??? Haven't heard that one...
    The De-Interlacer in the Tosh 900E is very good indeed, but, depending on how much money you can get it for, I don't know if it's worth spending four times as much on it as - say - a Tosh 520E, which also gives a stunning picture. Don't get me wrong, the Tosh 900E is an excellent piece of kit, and I've seen it around for £300 SH, but there's every chance you'll be blown away by the 520E with NTSC Progressive signals anyway, and at around £170 it's definitely worth the money (and descent value).
    One thing the Tosh 900E doesn't do well (which I found out the hard way), is PAL/NTSC Progressive Conversion (i.e. PAL signals converted to NTSC then de-interlaced. But since you're a R1 DVD buff anyway this shouldn't really matter).
    If you can get a good price for your 42PW23P then you'll be well away, as the 42WH36 is showing up on Price Runner at just £1003-ish.
    N.B. - I was also blown away by the new Toshiba 42PW33P, the replacement for your current TV, so I'd say either would make a worthy upgrade.
  11. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    You'll be waiting for one hell of a long time :D
  12. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    The problem with LCD is it's not great at replacing a TV - depending on how much of it you watch. If you're an Avid TV viewer than you'll probably be better of sticking with your current crop of CRT RPTVs.
    The new Sanyo PLV-Z2 (£1400) is HDTV & 720p spec, and supports both PAL & NTSC progressive, and is looking very promising indeed.
  13. nathan_silly
    nathan_silly
    I guess some interlaced effects bother more than others... In order of the things that annoy me most (on any display)
    1) Damaged LCD panels (heat soak)
    2) PAL 50hz flicker on R2 DVD's on my set.
    3) Mpeg artifacts- blocking, Plasma gradients
    4) Terrible CRT geometry
    5) Large dead/lit pixels
    6) Poor blacks (LCD)
    7) Jaggies
    8) Scan lines
    9) Convergence/focus.
    10) NTSC judder.
    11) Minor CRT geometry.
    I don't watch TV anymore so I guess a LCD PJ is a viable alternative. Watch 1 film a day, and maybe a couple of animated DVD's (Simpsons, Futurama etc)
  14. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    LOL, so true.
    They are also a hint of things to come!
    Sorry Dimmy, I think we'll see the sets within a year. Remember, all we need is a DVI 720p input and that will allow connection to CURRENT DVD players/HTPC's and will also be compatible with any future HDTV set-top boxes (and likely HD-DVD).
    We may not have broadcast HDTV yet but the key to getting it is DVI/720p equipped set and the technology is a fairly minor leap above current sets.
    Paul
  15. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    That's a thought - if you're not using a Dimly Lit viewing room or (preferably) a rather dark viewing room than you may aswell forget LCD Projection already.
    If it were my money, I'd buy the RPTV, simply because it gives the better picture and it's the 'easier' option.
  16. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Your reasoning behind this thinking paul... :D
  17. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Nathan,
    I think you are looking at either a DLP HD2 projector or a decent 7"/8" CRT projector. After the Tosh, you simply won't be satisfied with anything less. LCD simply won't do it for you unless you look at a high-end model and if you are doing that you might as well go DLP HD2.
    You are used to a very good display and will not be happy with a lesser display, believe me.
    Paul
  18. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Which part ?
    Its the next logical step. Let me throw it back at ya - why do you think we won't see them in that time frame?
    Paul
  19. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Because - quite simply - we don't have HDTV and there aren't DVD Players with 720p Component Outputs.
    I doubt Toshiba are going to bring out a radical new RPTV product to cater for the HTPC market.
  20. nathan_silly
    nathan_silly
    What would be cool if current CRT RP's had this- a internal laser per CRT emits a grid onto the RP screen, automatically adjusting electrical focus, Schempluge, optical focus & geometry in relevance with the mirror & each CRT angle, this is then computated into each CRT and stored.
    Then a optical sensor automatically adjusts grey level and colour decoder balance.
    Probably impratical but would be pretty nice to have a self-calibrating CRT RP. :)
  21. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    haha - cost a fair bit too :)
  22. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Dimmy,
    Yes but we don't NEED HDTV to get hi-def pictures. The first step is DVI and there are current DVD players that do output 720p over DVI. You can also use an HTPC to output 720p. 720p IS Hi-Def. (However, we won't get true Hi-Def until HDTV / HD-DVD arrives).
    There are DVD players that output 720p component (although its frowned upon!) - have a look here http://www.keohi.com/keohihdtv/videodevices/momitsuv880/momitsuv880_background.html . Its also available in the UK now.
    DVI has now superceded component and you will increasingly see it on DVD players.
    The bonus is that a DVI equipped set will take HDTV broadcasts when they arrive.
    I admit its a chicken and egg situation but if a DVI equipped Tosh came out tomorrow, you could have it running 720p within seconds.
    I really think Tosh missed the boat here and suspect it may be some other manufacturer that brings DVI RPTV to the market first although Tosh will release one sooner or later.
    Paul
  23. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Well, pre-calibrated DLP projectors are available now. The Immersive Virtuoso is one but costs a pocket busting £8000. My favourite, the BenQ 8700 is exceptionaly accurate out of the box at a more reasonable £4700.
    Technology is catching up fast!
    Paul
  24. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Who's the smart money on?
    Sony possibly?
  25. bodyfodder
    bodyfodder
    Toshiba are going to release a LCos RPTVs soon and will prob be very expensive. Maybe they will skip DVi on (old) CRT RPs and concentrate on making their new Lcos ones hi-def.
  26. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Ahhh, the $64,000,000 question!
    Sony would have to be a good bet as they can be quite innovative at times.
    My real hope/dream is Toshiba in their next set after the this one but that might be more than a year away (NTSC only component - what were they thinking of!??) so thats why I reckon someone else may get the jump on them.
    Wouldn't be surprised if we saw something from Thomson!?
    Pure speculation though but things are moving very fast technology wise and adding a DVI input (providing the crt tubes are up to it ) would be a fairly cheap addition at the factory.
    I'll buy you a pint if I'm wrong :)
    Paul
  27. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Don't, you're giving me nightmares!
    I read a review of a Phillips 44" Lcos set and the grayscale was all over the place such that they couldn't get it anywhere near D65, great set crap picture - exactly what we don't need. Still, we shouldn't judge Lcos based on one set/review. Expensive though.
    Paul
  28. bodyfodder
    bodyfodder
    Thompson are also releasing a DLP RPTV very soon and looks pretty decent!
    That toshiba Lcos one on the american site looks the dogs danglies.................be a long time before we get that quality.
  29. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Now you are giving me wet dreams - stop it!;)
    Paul
  30. bodyfodder
    bodyfodder
    :laugh:
    As you said before Sony can be innovative but then the only product they have on the UK market with component inputs is their plasma range! Not even the LCD RPs have prog scan so i doubt they will add component inputs to CRT based RPTVs.
    A new range of LCD tvs from Sony are about to be released and they only have scart terminals.
