Toshiba XS32 dubbing questions
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rebecca, Oct 28, 2004.
  1. Rebecca
    Rebecca
    I have a problem understanding the concept of dubbing with DVD-R.
    In the Toshiba manual, I have found two different copy processes:
    1) High-speed or Rate-conversion dubbing: I understand you can copy edited titles from HDD to DVD-R with this.
    2) Creating a DVD-Video using a DVD-R: Also copying from HDD to DVD-R.
    What's the difference then? Does it mean that with 1) you cannot create compatible DVD-Video?
    If so, which is the best process? Should I....
    i) High-speed dubbing from HDD to HDD to convert a playlist into a title.
    ii) Then, copy this title to DVD with the "Creating a DVD-Video..." process.
    Am I missing something important??
    Kisses.
    Rebecca. ;)
  2. grumpy42
    grumpy42
    By this, I assume you are referring to the "DVD-Video Create" option in the edit menu.
    High speed dubbing and "DVD-Video Create" do exactly the same thing (High speed dub to the DVD), but the "DVD-Video Create" option allows you to select multiple titles to dub (as opposed to selecting "High speed dub" from the quick menu which only dubs the currently selected title)
    You can create a compatible DVD-Videos with either process (since they do the same thing). I have HS dubbed playlists without a problem (no HDD copy required) and the resulting DVDs have played without a problem on other players (old panasonic player, PS2).
  3. Rebecca
    Rebecca
    You are right, you can only dub one title from the Quick Menu.
    However, in the EDIT menu, there are two options:
    1) "Dub Selected Items": You can choose several titles and copy them to DVD.
    2) "DVD-Video Creation": It does the same thing!!!
    Which is the different between both? I thought 1) copied in VR-mode and 2) copied in Video-mode, but I am probably wrong...
    Apart from the fact that 2) let you configure how DVD menus should look like (colors and so on), I cannot see any difference.
    Could anyone clarify this?
    Kisses.
    Rebecca. ;)
  4. grumpy42
    grumpy42
    Now I understand
    The difference between 1) and 2) is that 2) will automatically finalize the disk after dubbing. 1) just dubs the selected content, but you will have to manually finalize it before you can play the DVD in other equipment.
  5. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    Option 2) copies video and then automatically finalises a DVD-R/-RW disc, turning it into a "DVD-Video" disc (which means it will play on DVD players). Once finalised you cannot add any more to the disc. With option 1) the disc remains unfinalised so you can add more content afterwards (if space allows).
