Toshiba XA1 Error Code?
Discussion in 'Blu-ray & DVD Players & Recorders' started by skinnymalinky, Dec 19, 2006.
  1. skinnymalinky
    skinnymalinky
    May 14, 2006
    813
    2
    28
    Boston Lincolnshire
    +62
    Hi guys tried to play superman returns uk disc and all i got was the following error code? 0x4094c202, could this be some kind of region coding?
    i've had no bother with other uk disc's?
  2. peahead
    peahead
    Dec 14, 2002
    3,243
    St.helens
    +550
    Its not a region coding error there is no region coding on hd-dvd or the toshiba player.
    a quick google brings a list of current toshiba player error codes.
    Toshiba Player Error Codes
    Content Error (ex. Invalid DISCID.DAT) 0x4093C003
    System Error (ex. Initialization Error) 0x4094C004
    Prohibited feature is used in Restricted Mode 0x4094C008
    Resource Load Failure 0x4094C00B
    Script Failure 0x4094C00C
    Markup and other Failure 0x4094C00D
    AACS Error for playlist loading 0x4094C201
    Fatal Error of AACS 0x4094C202
    Read/Parse Error of playlist file 0x4094C203
    Disc Error 0x4095C501
    PAL/NTSC Error 0x4094C502
    AACS Error for EVOB 0x4094C503
    Video Controller Error 0x4094C504
    Pixel Buffer Overflow 0x4094C601
    yours is Fatal Error of AACS 0x4094C202 whatever that means have you updated your player to the latest firmware 2.0.
  3. skinnymalinky
    skinnymalinky
    May 14, 2006
    813
    2
    28
    Boston Lincolnshire
    +62
    Cheers Peahead, yeah i'm running V2.0 and its only on that disc, the disc plays fine on my brothers 360 HD drive, weird :confused:
  4. peahead
    peahead
    Dec 14, 2002
    3,243
    St.helens
    +550
    Ye thats weird mate why would it work on your brothers 360 drive and not the toshiba :confused: dont now what else to suggest maybe get the disc replaced and try it again.
    I have the us superman returns and it work fine on my hd-xa1 the uk one shouldnt be any different.
  5. Dave2
    Dave2
    Sep 9, 2006
    3,967
    Newcastle Upon Tyne
    +531
    would be interesting to know if any other a1/xa1 people with a uk superman plays ok ?
    I have harry potter hd-dvd uk ver and plays ok in my hd-d1 so i cant see it is because it was a uk release ..... sounds a bit weired
  6. peahead
    peahead
    Dec 14, 2002
    3,243
    St.helens
    +550
    :confused: :suicide:
  7. skinnymalinky
    skinnymalinky
    May 14, 2006
    813
    2
    28
    Boston Lincolnshire
    +62
    I've just tried 4 other discs, 3 being uk ones all fine, popped superman in, plays the warner bros intro then thats it "error code" its deffo that disc, shame as its the only disc i got at the mo with True HD sound, very strange why it plays in 360 drive
  8. dUnKle
    dUnKle
    Jan 1, 2001
    16,010
    +2,994
    just got this 30 mins into Miami Vice
    Its a US disc from Movietyme playing on a US HDA1 player
    any ideas ?
    edit - my error code is 0x4094c00c
  9. harveyxxx
    harveyxxx
    Apr 20, 2006
    87
    11
    +3
    my miami vice plays the universal logo then error code
    simon
  10. dUnKle
    dUnKle
    Jan 1, 2001
    16,010
    +2,994
    do you get the 0x4094c00c error ?
    What firmware
  11. harveyxxx
    harveyxxx
    Apr 20, 2006
    87
    11
    +3
    hi i was using version 1.2 but upgraded 2.0 since doing so the disc has worked fine.
    simon
  12. dUnKle
    dUnKle
    Jan 1, 2001
    16,010
    +2,994
    how did you upgrade
  13. harveyxxx
    harveyxxx
    Apr 20, 2006
    87
    11
    +3
    hi i downloaded the nero image file from someone off this board then burnt it to disc using nero stuck it in ax1 and about ten minutes later it was updated.
    when i posted i hadn't watched the entire film. i did that today the first hour played fine but the rest of the film kept cutting out sound and speeding up so what ever the problem is it's still there.
    simon
  14. dUnKle
    dUnKle
    Jan 1, 2001
    16,010
    +2,994
    Few things I have found out
    (1) ... and most likely ... the disc is faulty
    (2) the disc requires the "official" 2.0 firmware as apposed to beta version to play
    I have a friend who has the official 2.0 firmware on his A1 and says his Miami Vice plays fine - however as he lives miles away I cant test my disc in his player
  15. Paulleahey
    Paulleahey
    Sep 8, 2005
    1,124
    Belfast
    +106
    I am just getting the exact same error code on my US Superman Returns and i'm running v2.0 firmware on my HD-A1 - v strange indeed. It's the only disc out of 25 that it happens with! Have plenty of other combos and TrueHD discs that work perfectly.
    Will have to return to Movietyme and get a replacement disc hopefully - shame cause I am dying to see it and hear it!
  16. Paulleahey
    Paulleahey
    Sep 8, 2005
    1,124
    Belfast
    +106
    Have just solved my Superman Returns problem on my A1 myself! When my A1 went for repair the engineer must have downgraded the firmware and then reinstalled a different v2.0 upgrade.
    I used the "Initialize" function on the Tosh maintenance menu and then reinstalled the v2.0 Nero image CD and it's working perfectly now! Happy days!
  17. AidenL
    AidenL
    Nov 16, 2005
    4,773
    Ireland
    +1,437
    I have the same problem with Miami Vice, and on King Kong as well? :confused:
  18. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    I have the same error message with batman begins from movieyme. what to do?
