Toshiba X32 Media
Discussion in 'Blu-ray & DVD Players & Recorders' started by blue2555, Mar 23, 2005.
  1. blue2555
    blue2555
    I have been using Datawrite Greys with theTosh X32, burnt over 125 no problems! But SVP.com have stopped selling them! and the similar replacement - Datawrite Titanium - I had a few coasters!.
    Anyone used the following (a little more costly)!
    Premium Quality Sony 8x Speed 4.7GB DVD-R (25 RETAIL TUB) £9.25
    PREMIUM Quality TDK 8x Speed 4.7GB DVD-R (25 FULL RETAIL TUB) £9.25
    http://www.digitalpromo.co.uk/erol.html
    From what I have read:
    The Bad: Datawrite - Yellow.
    The Good: Verbatum Pastel coloured TY02 Dye.
    Welcome your comments. :lease:
  2. SGM26
    SGM26
    I mentioned in a previous posting that I had 2 failures out of 25 with TDK 8x. They were not labeled premium, and I don't know if that would matter.
    I have been using Maxell and Memorex and have not had problems
  3. El_JimBob
    El_JimBob
    Dec 4, 2004
    115
    16
    I would add another thumbs down for the new datawrite (titanium) with the CMC dye - first batch was great but haven't had a single one work since.
    Gone back to using Ritek G04/05 discs - tried and tested.
    Whatever happened to the Fuji03 dye (used on the first batch of Datawrite Greys and 8x Printables)? I miss it terribly - what a great performer, and fantastic compatibility with other machines....
    Life just ain't fair guys
  4. blue2555
    blue2555
    I am a newbie to using the correct dyes on DVD- But I know that the old Datawrite Grey with Fuji dye was great!
    Please could somone tell me if the following is the same as the old Datawrite Grey- which has now been discontinued!
    DataWrite Fuji Grey Top 8x Speed Branded 4.7GB DVD-R
    £5.99
    ADVDinfo: Prodisc F01 / FUJIFILM03.
    Are there any other types available - with out a :suicide: non-coaster record?
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    As it says "ADVDinfo: Prodisc F01 / FUJIFILM03" this means they could be either Fuji or Prodisc. Reports are the Prodisc ones aren't so good. So it depends if you feel lucky...
    Mark
  6. jdarushall
    jdarushall
    Any tried these Ridisc ones yet???
    I've also seen Datawrite Optina blue for 10.99 for 50 which suposedly uses the Ritek dye???
