TOSHIBA WLT58 Settings Thread
Discussion in 'LCD & LED LCD TVs Forum' started by luke_1983uk, Nov 7, 2005.
Tags:
  1. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,067
    Essex
    +73
    32WLT58
    HDMI dvd player using a DVE disk (SD-350E)
    sorry people for the delay in my settings but here they are, i am very happy with them, i created them from the dve disk, which took ages, going backwards and forwards, but here you go,
    if you can see if there are any improvements to be made just let me know, thanks
    i set the backlight at 80 because i found everything too dark when set low even with the brightness set high, i just went for more of an even partnership between the two.
    if you find anything not quite right tell me.
    still really happy with mine! faultless set!
    BACKLIGHT 80
    CONTRAST 65
    BRIGHTNESS 66
    COLOUR 46
    TINT 0
    SHARPNESS 0
    BLACK STRETCH on
    MPEG NR low
    DNR auto.
    COLOUR TEMPERATURE normal
  2. ase001
    ase001
    Dec 1, 2004
    264
    Stoke
    +6
    Do these work for DTV when watching football, on mine the grass looks very artificial and cartoon looking. Although I get no blurring or movement issues just the grass looks crap.
  3. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,067
    Essex
    +73
    should do im pretty sure,
  4. stlic
    stlic
    Feb 17, 2004
    769
    +19
    Looks very similar to the settings I use myself luke. Only difference I see is blackstretch, I prefer it off.
  5. Undecided
    Undecided
    If that's a comment based on the recent ITV matches last week -ITV1 Bolton vs someone and ITV4 Middlesboro vs someoneelse wasn't it? - then my TV picture was rubbish also. Describing the grass as cartoon like sums it up perfectly.
    HOWEVER - and it is a big however - all other football I've watched has been very good, so I put it down to the transmission that night. I've watched quite a bit of footie since I got the set and that is the only time the picture was bad for me.
  6. Undecided
    Undecided
    Is anyone prepared to post a Dummy's guide to what each component does for this dummy?
    For example, I've played with Tint but I can't see it make any difference to the picture. And what's sharpness. And so on.
    Is there an order in which the components should be tweaked? Or does one just dive in an change anything you fancy?
  7. detra
    detra
    Sep 24, 2005
    78
    portsmouth
    ive ordered the dve dvd from play.com at £14.99 ready for the 37 when it arrives on monday will post my settings when i have run the disk has any one used it as any tips would be most helpfull
    many thanks :thumbsup:
  8. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    37 WLT58
    I have just ran DVE and got these base settings
    Backlight 39
    Contrast 42
    Brightness 56
    Colour 46
    tint 0
    sharp 0
    Blackstretch off
    It seem we are all getting very different results. Bear in mind that mine was done through a fairly basic DVD player using progressive component input. I am guessing another DVD player with another input would yield different results.
    I think what we need is for a HDMI dvd player using a DVE disk. That way it should be the best possible transfer of display. Also is the DVE disk really the best way of testing/setting up LCD's - I think most of the content was developed for CRT screens.
  9. stlic
    stlic
    Feb 17, 2004
    769
    +19
    You've got similar results to those originally posted in the WLT thread. Tried those settings and the colour seemed to be very accurate and even although personally I found the image too dark for watching in anything other than a dimmed room. The above setting are similar to those I use currently which seem to be a good tradeoff for daytime viewing.
  10. Funster
    Funster
    Oct 6, 2005
    57
    9
    Bromley
    I will post my settings this evening from using DVE on a SD-350E via HDMI.
    Cheers.
  11. ase001
    ase001
    Dec 1, 2004
    264
    Stoke
    +6
    Yes it was those games 'Undecided'. I hope the world cup next year will be better.
    What settings are you using for football matches, since blacklevels are not as important do I up the backlight?
  12. Undecided
    Undecided
    Changing settings for different progs is too sophisticated for me. I just leave them as they are which is (currently)
    Backlight 60
    Contrast 80
    Brightness 40
    Colour 40
    Tint 0
    Sharpness 0
    Black ON
    Mpeg Low
    DNR Auto
    Colour Mgt Normal
    These may change, for the simple reason that I am looking at this thread to see what settings others use.
  13. Funster
    Funster
    Oct 6, 2005
    57
    9
    Bromley
    37WLT58 - HDMI - SD350E using DVE
    Back light 46
    Contrast 50
    Brightness 48
    Colour 42
    Tint 0
    Sharpness -5
    Black Stretch OFF
    MPEG NR LOW
    DNR AUTO
    Colour Temp NORMAL
  14. po_man
    po_man
    Dec 23, 2004
    1,712
    St Albans
    +63
    Apologies for my ignorance, whats the difference between blackstretch ON or OFF? I tried it and nothing seemed to happen?
  15. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    With Balckstretch on , I can see the blacks get 'blacker', but what I also noticed is that details within the black can be lost.
    For instance - a scene with somebody wearing a black shirt with a breast pocket in it, The black will get darker with stretch on, but I found that you may no longer see the pocket on the black shirt. SO the choice is a deeper black, or a not so deep black but get more detail.
  16. Electric_Cat
    Electric_Cat
    Got the set arriving on Wednesday. Already got the Tosh 350E and new SCART cable. Is the HDMI cable that comes with the set any good?
    EDIT.
    Forgot to add, is it really worth the 15 quid for the DVE disk :confused:
    Is it not possible to get a reasonable result without it?
  17. SuperSeven
    SuperSeven
    Oct 29, 2005
    576
    28
    +30
    I have the DVE disk, but to be honest it wasn't really required.
    Regarding HDMI cable... neither the WLT58 or 350e come with an HDMI cable.
    I brought a 5m cable off eBay for about £15 and it appears to work fine.
  18. Eiji
    Eiji
    Feb 16, 2005
    1,423
    48
    +70
    Would I need the NTSC version of Digital Video Essentials (DVE) for NTSC calibration or would the PAL discs calibration also calibrate the NTSC picture?
  19. gareth78
    gareth78
    Nov 25, 2004
    97
    Woking
    Here's mine:
    Backlight: 40 (I increase this to 60 if i am watching in strong sunlight, not much chance of that happening now, and sometimes drop to 30 for watching films at night in a dark room. 40 is a good compromise for all conditions though)
    Contrast: 34
    Brightness: 50
    Colour:36
    Tint: 0
    Sharpness: 0
    Black stretch: Off
    MPEG NR: Off
    DNR: Off
    Colour Temp: Normal
    I have tried some of the other settings (higher colour/contrast) and when i went back to mine the looked quite colourless so give them a chance.
  20. Sunrunner
    Sunrunner
    Jun 14, 2005
    65
    Hello,
    This may seem like a bit of a daft question, but I have no shame !
    How is it you get to the black stretch and MPEG NR options on the 32wlt58. I went to JL yesterday and had a bit of a play with one, but couldn't get the picture to look very clear at all.
    I know the picture was never going to be great as it was from a very shared analogue signal, but the 37WLT58 had a better picture form the same feed so the only conclusion was the settings.
    I tried changing the pic settings so they were the same, but the 37 was still better. The only thing i can think of is the MPEG NR was higher on the 32 but how do you change this.
    Would love to get this TV as it really is a steal at the moment, but have to see it with a half decent picture before I can justify it.
    Sunrunner
  21. mickbirch2000
    mickbirch2000
    Nov 30, 2004
    857
    46
    Bournemouth
    +222
    I have 37WL56 for 2 months & have played with the picture settings a lot to try to get blacks black without losing detail in dark areas & overall brightness.
    My current settings which give me the best compromise:
    BACKLIGHT 60
    CONTRAST 60
    BRIGHTNESS 40
    COLOUR 32
    TINT -20
    SHARPNESS -4
    BLACKSTRETCH ON
    COLOUR TEMP COOL
    MPEGNR OFF
    DNR LOW
    CINEMA MODE doesnt seem to do anything that I can detect
    I have not got any devices connected via HDMI yet, above settings work well for me with SKY+ via RGB & DVD via component.
  22. ash
    ash
    Jun 9, 2005
    11,320
    +398
    What about normal viewing, all the thigns you listed are for DVD's right?
    What about watching SKy etc.
  23. cooldawn
    cooldawn
    Oct 30, 2005
    942
    +74
    I've been going through some of the settings here and as far as I can tell most are way off (but I must stress that these are via Freeview only). Does anybody think certain sets may have different optimisation at the production stage!?
    Anyway, for the moment I'm sticking to 50 across the board (apart from colour which is 45) and will develop the picture over the next week to my optimised level so I should capture all type of programmes in all ambient light settings. I'll post final setting here later.
  24. dazzafact
    dazzafact
    Jan 9, 2005
    743
    +81
    Yeah thats my problem too, I must say i'm not running around the room screaming"This tv is fantastic, and well worth the 1880 hard earned english pounds on!!!!" I've got a spanking samsung hd950, the picture was crap with irreversible, better with salton sea, but still not super dooper. i have a sky box going into my 37wlt58 via a £30 scart lead and i'm getting loads of colour bleeding(I think thats what its called??!) Motion is a problem aswell. Can anyone assist, its me first lcd and im not sure whether Ive overlooked something. and I'll give it a week before my wife tells me we shouldve gone on holiday with the money, so ppppllllleeeaasssee!! :lease: :lease:
    Oh, my pc works a treat through me tv now, which is little comfort to be honest!
  25. detra
    detra
    Sep 24, 2005
    78
    portsmouth
    hi i hope you all have enjoyed fiddling with the settings i have just tried all the other posted settings and i have settled with the following (there seems to be quite a difference out there)
    BACKLIGHT 71
    CONTRAST 70
    BRIGHTNESS 53
    COLOUR 62
    TINT 0
    SHARPNESS 0
    BLACKSTRETCH off
    MPEGNR low
    DNR auto
    COLOUR TEMP warm
    i find sky+ changes quality between chanels and most have slight haze criss cross patterns in the background is this just the signal quality of sky? i have checked the signal test page and it shows 75% strength 65% quality should i get them to check the signal?
    the digital freeview is excellent considering a old areial in a place it says that i should not be able to receive it the pq is very good
    analoge is not worth talking about
    pc connected running hd film demo is unbeliveable seems even better than comets demo on a pioneer in store.
    happy fiddling
  26. detra
    detra
    Sep 24, 2005
    78
    portsmouth
    have you set the sky box to output rgb not pal and use input 1 on tv
    try the lead on another telly or try old lead you know was ok
    and do what i did with all the settings !!!!! have a good fiddle and make some notes of all the settings you use
    good luck :hiya:
  27. detra
    detra
    Sep 24, 2005
    78
    portsmouth
    i have the dve disk and i would not bother with it if i were you i used it for about 5 mins and decided to not use it again :D
  28. detra
    detra
    Sep 24, 2005
    78
    portsmouth
    same for me on tint and sharpness i did lots of differetnt settings in different orders but kept notes of all the changes so i could back trak if needed :thumbsup:
  29. Eiji
    Eiji
    Feb 16, 2005
    1,423
    48
    +70
    A friend of mine is going to borrow me his PAL and NTSC versions of AVIA - Guide to Home Theater on Tuesday so I'm sorted :thumbsup:
  30. Undecided
    Undecided
    Update on my previous reply to you about 'cartoon grass'
    I watched the rugby and the football on Saturday 12th Nov and, to my eyes, there was absolutely nothing wrong with the picture. No cartoon grass - in fact at times it was possible to pick out individual blades of grass. I couldn't see any motion blur either.
    Some younger, keener people out there might be able to detect some flaws - our old eyes are content with what we've got and I'm certainly not going to sit and try and find 'em, even if they are there!
    My wife is completely happy with the tele and, personally, I think it's the canine's genitals. It's our first LCD and we couldn't be happier.
    (Please, please, pretty please, don't let me regret writing that . . . . )
    (formerly) Undecided
