Toshiba Widescreens
Discussion in 'General TV Discussions Forum' started by gbr, Mar 13, 2002.
  1. gbr
    gbr
    Does anyone have any comments, good or bad on 28" Toshiba widescreens ?
    I own a Tosh SD210 DVD and also a Tosh video recorder, both good bits of kit, but I'm not sure about their TV's. I fancy a tosh because they have component video, but this would not be an overriding feature.
    My other considerations are JVC, either WT5 or WFT1
  2. Doubledoom
    Doubledoom
    Tosh larger sets are usually very good. However, their 28" sets are generally budget models. They also don't seem to be releasing the newer versions in 28" form.
    You should really look at 32" as a minimum. 28" sets look really small in the home.
