toshiba vs samsung
Discussion in 'LCD & LED LCD TVs' started by riri23, Jan 15, 2005.
  1. riri23
    riri23
    hello i want to buy a lcl tv screen but i must choose between the 2:
    -toshiba 23WL46
    - samsung 22N23 or LT-P227W
    both are at a same price arround 1000-1100€
    thank for your help
    See u
    riri23
  2. Skiny
    Skiny
    Aug 18, 2004
    278
    16
    Post the specs, and a little more info. They are both good makes. I personally prefer Samsung.
  3. imh
    imh
    You not going for the Toshiba 32WL48?
  4. riri23
    riri23
    I must choose between 22 or 23' because of the size of place where I'll put the tv screen!
    here are the spec :
    Samsung 22N23 : price 1132€
    TV/Video
    HD-Grade 1280 (H) x 720(V) pixel resolution
    Widescreen Aspect Ratio
    600:1 Contrast Ratio
    450 cd/m²
    V-Chip System
    NTSC Stereo Tuner Built-In-181 Channels
    Samsung DNIe ™ (Digital Natural Image Engine)
    - Detail Enhancer
    - Contrast Enhancer
    - Motion Optimizer
    - Color Optimizer
    PC Picture-In Picture with Split Screen
    170°H)/170°V) Viewing Angle
    Fast 16ms Response Time
    3D Y/C Digital Comb Filter
    Improved Cable Management
    Power Adapter Built-In No External 'Brick'
    Audio
    Bottom Built-In Speakers with 5 Watts x 2 Audio Power
    MTS/SAP Stereo Sound
    SRS WOW Surround Sound
    And the toshiba Stasia 23WL46G : price 900€
    Tuner Multi-standards : oui
    Ecran Black Stripe : oui
    Format : 16/9
    Taille : 58 cm
    Image Angle de vision : 176°
    Contraste : 400:1
    Luminosité : 450 cd/m²
    Résolution : 1280 x 768
    Entrée(s) Audio RCA : oui
    PC : oui
    Péritel(s) : 2 (RVB)
    S-Vidéo : oui
    Son Virtual Dolby : 2x3W RMS
    Sortie(s) Audio : oui
    Casque : oui
    Subwoofer : oui
    Traitement(s) d'image Colour temperature : oui
    Digital Comb Filter : oui
    So here is my comparaison :
    Samsung 22N23 :
    Pro :
    -Contrast ratio and cd/m²ratio
    -Picture-In Picture
    -DVi interface
    Cons :
    -22' vs 23' for toshiba
    -Price
    Toshiba 23WL46G :
    Pro :
    -Price (less 232€ from samsung)
    -23' vs samsung 22'
    Cons :
    -Contrast ratio
    -Light ratio
    -no DVi (but is it important?)
    Thanks for your feedback
    Riri23
  5. Moomin1977
    Moomin1977
    I've read all the postings on the Toshiba 23WL46 but none seem to offer a definitive answer as to whether this is indeed a decent LCD or not. Please can someone elaborate further?
    I was also considering the Sony 23" LCD but was put off by reports of an annoying buzzing sound from the unit?
