Toshiba TV, Problems with video game hook up
Discussion in 'General TV Discussions Forum' started by dstar2349, Sep 8, 2005.
  1. dstar2349
    dstar2349
    I have a toshiba tv with 4 different (white, yellow, red) outlets to which i can plug my video game into. One in the front, and three in the back. I don't have the original remote to the tv, but i have a universal. I've tried pluging the gamecube into all of these plugs and i can't get it to work. The tv doesn't have like a AUX channel, or a tv/video button. Any suggestions. Thanks for sure.
    Later
  2. sniper007
    sniper007
    does it have a scart,if so you could get a connecter that turns your 3 leads into scart,then plug it in and turn your game cube on and your tv may switch aotomatically to av.also you are looking for av channel not aux!!!or a button with a small box with a small arrow pointing in to it!! :thumbsup:
  3. dstar2349
    dstar2349
    what is a scart
  4. longleyc
    longleyc
    Scart socket -
    A SCART socket is a 21 pin connector fitted on many European TV, VCR, and Satellite products, it provides stereo sound and video signals both in and out of the item of equipment (obviously depending on the particular type of equipment), it can also provide RGB signals, which can be useful for connecting Video Game Consoles or Digital TV Set Top Boxes (STB's).
    Pin 8 provides signal switching. When you turn on a VCR the TV will automatically switch to the Line in of that feed.
    Sometimes they are named L1, L2 etc or Av1, Av2.
    Your video game is using the composite cabling. Yellow for Video signal and White/Red for sound.
    You can get a scart ended lead for the video game and if it supports Pin 8 switching, then it will appear on the tv.
    Else continue using the lead you currently use but as sniper007 says, you must switch the tv from tuner input to AV input. (Thse are the connections on the back and front of the tv).
    Im afraid you should have to get the remote which operates the tv properly to change to AV
  5. Padi
    Padi
    If used to have a similar problem with a sanyo tv. No matter what universal remote i tried none would let be use the AV channel. In the end had to plug the console in to the scart input on my VCR then connect the VCR to the tv using the RF cable so i could tune in to the vcr channel. Hopefuly you wont have to do this but its a possibility until you find how to connect directly to the tv
  6. longleyc
    longleyc
    Good idea Padi, using the Video L1/L2 scarts :)
