Toshiba TV making high pitched whistling noise
Discussion in 'TVs' started by Lex, Jun 17, 2005.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Guys,
    My old(ish) Toshiba 28W23B in my bedroom has started making a high pitched whistling/screaming noise which is getting worse by the day! :mad:
    Am guessing that it's the line output transformer - any other ideas? Any suggestions for sites that sell tv parts?
    Cheers :smashin:
  2. scooby do
    scooby do
    Dec 11, 2002
    1,765
    48
    +37
    Does a tap on the chassis make any difference? Could be a vibration problem, glue gone off
  3. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    LOPT's usually whistle when they have failed. I'd check the sugestion above first ;)
  4. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Nah, I gave it a good kicking but that didn't help! :(
    Any recommendations for places that sell tv spares?
  5. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, but it could be anything, you haven't tracked it down to a component yet ? it could be the LOPT but equally it could be a simple faulty electrolytic capacitor. (LOPT's can be obtained from CPC.co.uk) My advice is not to take the back off unless you are experienced in TV repair work. Not very helpful I know but my advice is meant in the best spirit. Regards, yt.
