Toshiba TLP-X10E - is this a good deal?
Discussion in 'Projectors, Screens & Video Processors' started by jets, May 24, 2002.
  1. jets
    jets
    Hi!
    I have the opportunity of buying a Toshiba TLP-X10E LCD projector for $1120. It has been used around 25 hours(!)
    My needs is: a projector for DVD movies and video/TV on 100" and my budget is limited to $1300, which unfortunately makes it hard to buy a decent CRT. Daylight will be shut out of the showroom.
    Quick specs:
    LCD, 2000 ANSI lumen, 400:1 contrast, zoom 1.3:1, HDTV: 1080i,720p, 1024x768.
    Is this a good deal? Should I buy it or look for something else?
    Also, if you have any experience (good or bad) with the projector, I would really appreciate your comments.
