toshiba tdp mt500 power cable to short!!
Discussion in 'Cables & Switches' started by mh8701, Mar 15, 2006.
  1. mh8701
    mh8701
    Dec 10, 2005
    239
    16
    what can i do to rectify this/ its a 2m cable and it needs to be about 3m each end of the wire thats conected to the plug and the projecor insert is sealed!
    please help
  2. mh8701
    mh8701
    Dec 10, 2005
    239
    16
  3. Dean25
    Dean25
    Aug 7, 2005
    135
    Reading
    +8
    When you say the projector insert is sealed do you mean that the power cable is fixed into the projector?, or do you mean the plug on the end of the power lead is moulded onto the cable. If the cable is removable then just buy a longer mains cord from somewhere like rs components, if however the cable is not removeable, wire an iec plug on and buy or make you're own longer iec lead up, either one of these products should help you out: http://www.maplin.co.uk/Module.aspx?ModuleNo=1360&criteria=Mains Power Connectors&doy=16m3 or
