Toshiba Signal problems?
Discussion in 'LCD & LED LCD TVs Forum' started by Hors1na, Feb 6, 2009.
Tags:
  1. Hors1na
    Hors1na
    Jan 21, 2009
    2,135
    On that ledge just under the broken window by that
    +462
    I've had my toshiba for about 2 weeks and it does the same thing! It's really annoying, the screen also regularly goes black and a lot of blocking occurs quite frequently as well!!:eek:
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Sounds like signal interference, check signal/strength, does it happen at certain times, such as when the central heating comes on or the fridge or even light switches, all worth a check.
    Curly
  3. Hors1na
    Hors1na
    Jan 21, 2009
    2,135
    +462
    Come to think of it the washing machine was on. How would that make a difference though? I have never had signal problems before. Are you saying I will have to put up with it every time I use the washing machine?:eek:
  4. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    either that or get your aerial checked.
