Toshiba service mode
Discussion in 'General TV Discussions Forum' started by gcogger, Mar 16, 2002.
  1. gcogger
    gcogger
    Mar 16, 2002
    402
    Southampton
    +56
    I've recently got a Toshiba 32Z13B which seems good, but the geometry is not great.
    I've worked out how to get into service mode to adjust the PARA, CNR etc., but I can't bring up any test patterns or get into convergence mode.
    I've trawled the web and this group, and the 2 methods for entering convergence mode don't seem to work (the '7' button or the yellow teletext button). Does anyone have any ideas?
  2. Doubledoom
    Doubledoom
    Check google under the uk.media.home-cinema newsgroup.
    The Tosh models share most the service and designer menu options. it is just the values that vary.
  3. njm32
    njm32
    Nov 23, 2001
    22
    3
    Dorset
    When in service mode pressing the ext.input button on remote should cycle through RED, GREEN, BLUE and crosshatch. It is the latter you need for setting geometry correction. I do not think there is a convergence menu, colour CRTs nowadays are pre-converged (except of course RP sets which use 3 mono tubes and convergence is a regular adjustment).
  4. gcogger
    gcogger
    Mar 16, 2002
    402
    Southampton
    +56
    Thanks - I'll try that.
  5. gcogger
    gcogger
    Mar 16, 2002
    402
    Southampton
    +56
    OK, tried it. Unfortunately, the ext input buton does nothing in service mode :-(
    Any more ideas, anyone?
