Toshiba Service Menu ???
Discussion in 'Televisions' started by Blighty_Boy, Oct 27, 2003.
  1. Blighty_Boy
    Blighty_Boy
    how do you get to the Service menu on a tosh 32ZP18
    thanks in advance :)
  2. Blighty_Boy
    Blighty_Boy
    anyone ???
  3. Demon
    Demon
    Dec 13, 2000
    954
    Cheltenham
    +57
    it should be
    You need to be infront of the tv, and have access to the 'menu' button on the TV itself..
    then
    1. Press Mute on the remote control
    2. Then press Mute again, and at the same time hold the menu button down on the TV, ideally the mute should be pressed slightly before the menu button. Hold the Menu button down for at lesat 1-2 seconds...
    When you are in service mode, you will notice an 's' in the top right, and some label/data on the top left.
    To exit, simply put the set into standby, then switch it back on.
    PLEASE WRITE DOWN ANY VALUES BEFORE CHANGING!!!!!
  4. Blighty_Boy
    Blighty_Boy
