Toshiba service menu
Discussion in 'General TV Discussions Forum' started by ultimatenyle, Nov 27, 2001.
  1. ultimatenyle
    ultimatenyle
    anyone know how to get into the service menu on toshiba's 32Z17B or where i can get the service manual and if it has circuit diagrams?
    cheers
  2. Doubledoom
    Doubledoom
    The Toshiba service menu is well discussed on the newsgroups (as well as in here). A good resource of information is to check Google under the uk.media.home-cinema newsgroup with the content "toshiba service menu".
    You will get loads of messages about the Service and Designer menus. All the toshiba sets share the same method to get into both menus and most of the base settings are the same. Only the values differ.
    The service manuals do include circuit diagrams and thats about it to be honest. Do not expect to see any reference to the designer menu codes and only very limited information about the service menu.
