toshiba sd900e multiregion
Discussion in 'Blu-ray & DVD Players & Recorders' started by filmman, Mar 29, 2002.
  1. filmman
    filmman
    Nov 10, 2001
    300
    2
    brighton
    +15
    hello
    i am considering buying a multiregion sd900e and i was wondering if anyone has had problems with region1 discs (jeepers creepers,rce etc)
    many thanks.
  2. encaser
    encaser
    Mar 15, 2001
    3,624
    Suffolk/Essex
    +1,232
  3. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    I have said machine and did have problems with RCE titles, but can work around them now I know how! Simply pop in the disc and press stop before the Region Map comes on. Then select 1 second and press play and the movie will play. There are other ways to watch certain extras, by chosing titles etc, but you may never be able to actally see the menu screens on some discs (shame)?
    Kane
  4. stewarthollyhead
    stewarthollyhead
    why dont you wait for the 950e thats coming out in the next 8 weeks :)
  5. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Oh, it's called the 950E now!? Can you please tell me where you heard it would be out in 8 weeks, as I may see if it is worth trading in the 900E?
    Cheers Kane
  6. stewarthollyhead
    stewarthollyhead
    I rang toshiba and basically had a converstsaion along these lines:
    Stewart: HI can I have some advice
    Tech guy: sure
    Stewart: Well I was thinking of buying a Toshiba
    Tech guy: Great keeeps me inn a job
    Stewart: Well, isn't the 900e the one to go for?
    Tech guy: At the moment, yes
    Stewart: So the rumours are true there isw an upgrade coming or a new model
    Tech guy: fraid we can't dsay anymore at the moment
    Stewart: Look mate, no offense but if you spent £1300 on a DVD player and they bought out anewer version a few weeks later you'd be pretty miffed.
    Tech guy: Can you hold the lin a second?
    Stewart: sure
    Stewart waits... waits.... waits...
    Stewart starts to think phone has gone dead but waits....
    Tech guy: Hello?
    Stewart: hi!
    Tech guy: OK um... not supposed to say thisyet but there will be a Toshiba upgrade in April/May time. Details sketchy as of yet but it will be TOSHIBA 950E.
    Stewart: OK, I wont tell anyone.
