Toshiba SD510 with crt Barco projectors
Discussion in 'Blu-ray & DVD Players & Recorders' started by torkus, Jul 19, 2002.
  1. torkus
    torkus
    Jul 2, 2002
    29
    Essex
    I'm in the process of buying a crt Barco 701 PJ soon and wanted to know if it will be OK at accepting a feed from the o/p of my Tosh SD510 player via the progressive scan connection?
    I understand that the Barco does progressive scanning for region 1 DVDs.
    The supplier I bought my DVD player from said that it is NOT macrovision disabled! so I thought I'd check with the techies at Toshiba UK and they re-assured me that there shouldn't be a problem outputing a signal through the component phonos of the player into the projector. Can anyone confirm this?
    All feedback would be appreciated!
    :confused: :confused:
