Toshiba SD390 Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by smudge18, Jun 12, 2009.
  1. smudge18
    smudge18
    Jun 18, 2006
    50
    Hello, does anyone have a multiregion hack for the Toshiba SD390 please?
  2. rs59
    rs59
    I found this on another forum: Toshiba SD390.
    It appears to be the same hack as that used for the SD190, which I found here: DVD Hacks Discussion Forum - DVDhacks community: Toshiba SD190
    - Power On
    - Open Tray
    - Press 9879 0 (0 stands for Multiregion, you may press buttons 1 to 6 to choose a specific region)
    - A Message appears stating that "The Reg.No was changed to region 0"
    I hope this helps.
    Please let me know if this works, as I'm interested in purchasing a Toshiba SD390 myself, after seeing a very good review in one of the Home Cinema magazines.
  3. rs59
    rs59
    Can anybody else confirm or deny if the hack I gave above works for this player?
    I've had one source confirm that it worked for them, but another cannot get it to work for his player.
    Thanks in advance.
  4. GS1
    GS1
    Oct 18, 2006
    10
    4
    Farnborough, Hampshire
    Yes the hack works.
    Not a bad machine for £40. :thumbsup:
  5. Vicarious_Eyes
    Vicarious_Eyes
    Oct 19, 2009
    450
    Edinburgh
    +43
    Just applied this hack and watched a region 1 DVD with it - thanks!
    Also, the first time I've hooked this up via HDMI - looked great and has shown up the SD Freeview picture to be awful by comparison!
