Toshiba SD370E Upscaling DVD Player & 32WLT66 Toshiba LCD TV
Discussion in 'Blu-ray & DVD Players & Recorders' started by andrews72, Sep 13, 2007.
  1. andrews72
    andrews72
    Sep 13, 2007
    7
    Hi Hi have a Toshiba 32WLT66 LCD TV which is currently connected via SCart to an aging Sharp DVD Home Cinema System, (non-progressive scan). I also have the Toshiba Sub-Woofer.
    My question is this. If I buy the Toshiba SD370E upscaling DVD player, am I likley to see a noticable improvment in DVD playback. The sharp produces what i think ar pretty good images anway, so I wonder whether I am making the best use of the TV or not?
    Is it true to say that HD TV's upscale all footage to a certain degree, in order to display them at the TV's native resoltion? If so the question has to be whether the HDMI DVD player will upscale the images to a higher quality than the TV?
    Surely the upscaling abilities of the TV (given is much higher price) far exceeds that of a £60 upscaling DVD player?
    Lastly, will a tru HD DVD / Blue Ray player upscale standard DVD's any better than say the SD370E?
    A lot of questions here, so thanks for any help.
  2. blue max
    blue max
    Apr 12, 2006
    12,946
    London
    +4,314
    I think the 'upscaling feature' is a red herring. However, by using the hdmi connection the picture is much improved (to my eyes). I have a panasonic lcd 32in tv and the old sd360e, which is a similar setup to yours. I would go for it!
    Graham
  3. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    With that combo you will see an improvement, the player will upscale better than the display, because I've tried it with that equipment. I wouldn't buy the 370E though because of the freezing issue.
  4. BrianPK
    BrianPK
    Sep 10, 2004
    2,479
    83
    +273
    I am almost certain that a Blu-ray or HD-DVD player would do a better job of upscaling than a £50 Tosh. 370e player but having said that I was amazed at the quality of the upscaled image from the 370e on my Pana. 42PX60 plasma compared to my Pioneer dv- 575 player.In my case the 1080i and 720p images are superior to the basic hdmi connection but beware ....the 370e player has a downside.It has a bad habit of freezing the picture for about 5 secs. once every couple of hours of viewing and then carrying on as normal.It also struggles to recognise(but eventually succeeds) some dvd-r discs.If you are easily irritated then this may not be for you but it has a mighty picture:)
