Toshiba SD350 - DivX Aspect ratio ??
Discussion in 'Blu-ray & DVD Players & Recorders' started by DennisT, Oct 21, 2005.
  1. DennisT
    DennisT
    Any Tosh users out there ??
    A question... when replaying DivX movies is the aspect ratio as its supposed to be.
    The reason I ask is on a recently purchased philips 630, the player applied anamorphic compression before it sent the picture to the YV... the result was every movie ended up "squashed" on the screen, as the anamorphic compression was appled twice. Using every adjustment on the TV and DVD player it was not possible to correct the aspect error. Its going on Ebay ... back my cheapo Yamasa that plays everything perfectly but with only average picture quality!
    Not keen to layout more cash on the Tosh if the same problem exists !!!
    Appreciate your help folks.....
