Toshiba SD340e Hot Discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by y220186, Jan 18, 2005.
  1. y220186
    y220186
    Dec 24, 2004
    38
    Just got a new 340e and have found that after watching the DVD, when you remove the disc, it is extremly warm, not too hot that you couldnt touch it but its the hottest Ive ever known a disc to get,
    Anyone else have this same issue,
    Anyone have a 340e that discs dont get hot in ?
    Anyone know is this is a problem ?
  2. Raze
    Raze
    Dec 21, 2003
    875
    UK
    +13
    I guess your 340e is working hard - it's a darn good player!
  3. superkully
    superkully
    Sep 29, 2004
    48
    Even if I've been watching for 21/2 hours the disc doesn't get more than slightly warm when I eject...
    Is the disc scratched or are you playing MPEG-4s off of the disc?
  4. y220186
    y220186
    Dec 24, 2004
    38
    It doesnt matter what its playing, brand new discs, older discs, dvdr-r , dvd+r, all of them run hot.
  5. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    is the player in a well ventilated place? i.e. not in the middle of a stack of AV equipment.
    actually, as you're here have you noticed any problems with brightness levels with your player? having to readjust it from your normal levels etc?
  6. superkully
    superkully
    Sep 29, 2004
    48
    weyland, I have to change the level sometimes (don't know why...).
    I've also noticed that it seems to switch to composite output randomly (as far as I can tell)...
  7. y220186
    y220186
    Dec 24, 2004
    38
    Damn, I knew this one was coming, it is sat on top of my receiver, but I have raised it slightly to increase the distance between the two. However, its well ventilated and the bottom of the dvd player itself, is almost room tempearture. Nowhere near as hot as these dvds.
  8. y220186
    y220186
    Dec 24, 2004
    38
    As for levels, Ive just had delivered a ntsc superbit spiderman 2, just popped it in the player and had to adjust the brightness and contrast.. Weird, unless its an PAL NTSC thing.
  9. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    i think there is a definite difference in brightness from PAL to NTSC. NTSC is much darker on this player than ANY other player i've owned.
    so you say your superbit title played ok? my R2 superbit of blackhawk down freezes every 5 seconds, or so. :(
  10. L00py^
    L00py^
    Sep 23, 2004
    131
    Does a Toshiba SD-340E unit play x8 -R disc please, I am planning to record them using my Toshiba RD-XS32 unit?
  11. superkully
    superkully
    Sep 29, 2004
    48
    loopy - might depend on the DVD make, but it does play my Ritek and Datawrite ones.
  12. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    actually, that should be the PAL pic is MUCH brighter than any player i've owned.
  13. y220186
    y220186
    Dec 24, 2004
    38
    Well watched the superbit last night, played flawlessly, except for having to adjust the image slightly, I also have black hawk down coming, should be here toda, so will test tonight.
    Also, does it matter what software you burn with for DVD-r's as Ive been using datawrite grey's for a while, and about 50% of those the picture breaks up after about an hour, and the remainder of the film simply stops and starts every couple of seconds, unwatchable. Im using Clonedvd2 to burn.
  14. cuseeme
    cuseeme
    Mine won't play *anything* recorded on my SX32 at all :-(
