Toshiba SD340 Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Pete3rd, Mar 1, 2005.
  1. Pete3rd
    Pete3rd
    Hello
    I recently bought a Toshiba SD340 and used a handset hack to make it multi regional. All seemed fine it played region 1, 2 & 5 disks no problem, however it will not play 3 Disney region 1 disks I have bought recently (worked fine on my old Wharfedale M-5) and refuses to play another pre-recorded region 2 disk just displaying DVD-R and refusing to access it?
    Some new audio CD's also will not read. These have not been mistreated at any stage and are pre-recorded originals!!
    When the CD/DVD's refuse to play the disk drive seems to make quite a loud humming before refusing to play.
    Has anyone else experienced this with a Toshiba player?
    Basically will I get the same symptoms with a replacement or have I just unluckily picked up a knackered player? :confused:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    23,184
    Warwick
    +3,785
    Might have more luck/responces if you re-post on the DVD players forum. This forum is for recorders.
