Toshiba SD330e + spiderman problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Shimmyhill, Dec 21, 2003.
  1. Shimmyhill
    Shimmyhill
    I just picked up a Toshiba sd330e and so far i have been pleased with it.
    However while i was watching Spiderman (R1) it frooze and would not continue playing past the scene, you could go back ok but could not forward past the freeze.
    I skipped a couple of chapters and it happened again.
    Is this likely to be a disc error, a compatability problem etc.
    Every other disc i have played, both r1 + r2, have played flawlessly.
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Have you tried the same dvd on another player? Sadly if theres one thing that isn't great on the toshiba its the dvd loader, mine started playing up after less than a couple of months and I sent mine back to Amazon and got a refund. Others have reported frame skipping problems. However enough of my negative vibes. Things will be a lot clearer once you know if the dvd is geniunely poor/faulty or its just your player.
