Toshiba SD330, the 220's replacement?
Discussion in 'Blu-ray & DVD Players & Recorders' started by JIT, Mar 29, 2003.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    Saw this in a brochure i got from www.unbeatable.co.uk saying it was the replacement for the 220.
  2. Falconer
    Falconer
  3. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    Why is it that the Toshiba website is always the last place on the net to have info on their own products?
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,228
    UK.
    +2,764
    You can get the SD520e for £175 on the net (and Richer will price beat if the other place has it in stock), and it has a higher quality DAC than the 220, so if that's not to expensive, you could try model instead.
    It also does progressive san on ntsc if that's of any use...
    Gary.
  5. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    Must be about time for a replacement for the 520 too - their lifespan seams to be lessthan 12 months these days ... maybe it will have PAL Prog-Scan too.
    Vikki
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,228
    UK.
    +2,764
    That was what I was wondering - it can only be around the corner considering the amount of machines currently in the shops with (or hackable to) PAL progressive.
    I'm quite impresed with the machine considering it's availaible quite cheaply now, and for me, the image is better than the Philips 963 I had (sent it back), and they both have similar DACs..
    Gary.
  7. bowenjones
    bowenjones
    Oct 24, 2002
    2,800
    Wales
    +443
    Well, you can get the replacement for the 120 here....
    http://www.dvdplayers.co.uk/toshiba-sd125e.htm
    Looks like they are upgrading the entire range.
    A lot of manufacturers seem to be placing the display
    on the sides of the player now rather in the centre.
    I think this is a good thing as currently my Tosh. 220's
    display is obstructed by my cabinet doors.
  8. churchwa
    churchwa
    All I want is Pal prog :(
    Now Tosh please do the right thing and give it to me :)
  9. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
  10. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    i dont like it. A friend of mine has a SD-125e and to be honest, i prefer the looks of my (admittedly basic looking) SD-210e. I didn't get much of a chance to play about with it, but i wasnt convinced at all. The picture quality at a first glance looked pretty terrible when compared to mine.
  11. galito
    galito
  12. Tubbs
    Tubbs
    Does the SD330 do progressive scan?
  13. JimmytheSaint
    JimmytheSaint
    Mar 21, 2003
    1,793
    London
    +100
    I've had the 330E for about a month now (grey import) and it is very similar to the 220 in almost every way. It does not do prog scan or anything new and cost about £120 multiregion. Picture and sound were impeccible, however it had sync issues with svcd's and as a result I returned it and bought a Limit 900A from RS instead. It was only £150, PAL prog, NTSC prog, DVD Audio and played everything I threw at it perfectly,
