Toshiba SD330 Problem with DVD-R
Discussion in 'Blu-ray & DVD Players & Recorders' started by clevejon, Sep 24, 2005.
  1. clevejon
    clevejon
    I have just purchased a Panasonic DMR-ES10 DVD writer and started recording TV programmes on Tesco 8x DVD-R media.
    These replay fine on the Panasonic writer, but when I try to read them in my Toshiba SD-330 DVD player, I get "Disk Error" and nothing else happens.
    I checked the manual and the Toshiba is supposed to be compatible with DVD-R but I can't tell if the 8x speed is supported (doesn't say) in the manual.
    Any ideas?
    clevejon
  2. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    It might not like cheap media. I've read a few things on this forum where people have had problems with Toshiba's not reading discs other brands like Panasonic and Pioneer can read. Try a verbatim dvd-r and see if the Tosh is ok with them ?
  3. Turrican
    Turrican
    Sep 9, 2005
    17
    I've got the same problem with my SD-350, i contacted tosh and they recommended TDK, Panasonic or Fuji branded media.
    I've bought some TDK DVD-R's and so far they have been perfect, also i have now started burning at 4x instead of 8x, just in case.
