Toshiba sd330 - media compatibility
Discussion in 'Blu-ray & DVD Players & Recorders' started by swanny65, Dec 29, 2004.
  1. swanny65
    swanny65
    the instructions for my Toshiba dvd player indicate it should play dvd-r media. however i am struggling to get the player to recognise my tdk media after i have burned the dvd from my pc. other postings within the forums indicate that, whilst the Toshiba sd330 is an excellent value player, media matching with this player can be tricky. has anyone any media recommendations or should i give up and buy newer model that is compatible with the latest formats.....again recommendations would be welcomed. thanks
  2. swanny65
    swanny65
    A brief update as i've found media that is compatible with sd330.
    Mirror Platinum DVD-R x4 speed (2 for a quid at Poundland)
    i've also order a trial pack from http://www.cd-rmedia.co.uk and will update on compatibility later.
    finally Toshiba's technical support advise not to use media faster than x4 in this player.
