Toshiba SD330 connecting to JVC AV28R25
Discussion in 'Cables & Switches' started by stone-age, Jun 16, 2003.
  1. stone-age
    stone-age
    Recently purchased the above items and have them connected via scart to EXT-2.
    When I switch the Toshiba on the JVC automatically switches over to EXT-2, whether there is a DVD in the player or not.
    The same happens with my video recorder to EXT-3.
    When switched off the JVC stays on the same channel and does not revert back to EXT-1, the Sky connection.
    Is there a way to change this?
    I've looked through the manuals/checked the settings and can't find anything.
    Any help appreciated.
  2. DaveP
    DaveP
    They are designed to do this, however, it should go back to AV1 when you switch the Tosh off. Have you definitely got scart control set on, within the sky setup menu?
    The other question is: can you connect the DVD player to the VCR scart of the digibox? I assume not, you've presumably got the VCR connected to that!
    DaveP
  3. stone-age
    stone-age
    Cheers, I'll check the Sky menu (if I can find it)
    I already have a scart lead attached to the VCR scart on the digibox to let me view Sky on another TV in another room.
