Toshiba SD24VB & SD26VB VCR/DVD Combi
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by mothtoaflame, Jun 24, 2005.
  1. mothtoaflame
    mothtoaflame
    Anyone know the hacks for the above players?
    Thanks!
  2. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,174
    63
    Location location location
    +93
    No handset hacks for these, you either buy them pre-modded from a specialist dealer, or have to have them upgraded.
  3. daveyjay
    daveyjay
    Nov 18, 2004
    59
    +10
    For Toshiba SD-V26
    1: Switch On the player
    2: Press "pause" button on the remote
    3: Press "3" "1" "4" "1" "5" "9" button on the remote
    4: You can check on the TV screen as now you can set your region code.
    5. Press "0" button on the remote.
    6. Press "pause" button on the remote.
    7. Switch Off the player and wait for a few sec.
    8. Switch On the player and it works.
    Easy as Pi.
  4. 456789
    456789
    Mar 11, 2008
    5
    3
    Someone gave me one of these but it doesn't have a remote - will the mr hack work with an all in one replacement remote? (need a replacement for the tv too)
