Toshiba SD220e
Discussion in 'Blu-ray & DVD Players & Recorders' started by Unsure, Aug 12, 2004.
  1. Unsure
    Unsure
    Hello,
    I bought a Toshiba SD220e from Richer Sounds about two years ago. It was already multiregion and it has always worked with non region 2 dvd's. That was until a few days ago. I know get an error along the lines that the disc is incompatible (sorry not sure of the exact error).
    I was wondering if anyone knows how to rectify this as I have a lot of region 1 dvd's.
    Thanks in advance.
  2. Unsure
    Unsure
    Sorry for the bad english. 'I now get an error'.
  3. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    you need to find the firmware upgrade on the web, burn it to CD and the boot with the CD in the player. or take it back to Richers and get it done again.
    mine has lost its multi region settings twice now in about two years.
    i'm not sure where i got the firmware from do a serch on this forum and you'll find the link. hope that helps,
    Gary
  4. Unsure
    Unsure
    Will the firmware automatically make the cd bootable. Is it a simple procedure?
    Thanks for the quick reply.
  5. Unsure
    Unsure
    I have found the latest firmware and will try it out tonight.
  6. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    hope it went ok. if you followed the instructions it should have been fine. pls post and let me know.
    gary
  7. Dr_Mike
    Dr_Mike
    Mar 10, 2004
    379
    Loughborough
    +16
    Does anyone know if this firmware update let you play RCE disks ? My sd220 was bought MR from Richer Sounds, and as I understand it, won't play RCEs.
  8. Unsure
    Unsure
    Hi GaryD, I got it working. The update only took about 10 seconds and I tested it with a region 1 DVD and it worked perfectly.
    Dr_Mike what are RCEs?
  9. Dr_Mike
    Dr_Mike
    Mar 10, 2004
    379
    Loughborough
    +16
    RCE is Regional Coding Enhancement. It's something which Columbia Tristar and Warners put on some of their Region 1 releases (eg all the Superbit series) which prevents them from playing on some multi-region modified players. If you do a search on RCE on this forum you'll find lots of stuff!
  10. Unsure
    Unsure
    Thanks Dr_Mike and thanks to Dave regarding the info on the firmware.
  11. HitmanIP7
    HitmanIP7
    Jul 16, 2003
    789
    28
    UK
    +25
    Unsure: Where did you get your firmware update from, and how did you burn the disc?
    Ive got the same DVD player with a similar problem. Except mine seems to have started off as region 1, and was made multiregion. But now its reverted back to playing region 1 only.
    Ive tried the firmware which is easy to find with Google, but it never works.
  12. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    it does play RCE's.
    Gary
  13. Unsure
    Unsure
    I got this from another site, but can't remember which site it was.
    I copied and pasted the below text from the other site and are not my words, but work. (I had them in a a txt document)
    'u need to dload the rar file at http://sd220e.chez.tiscali.fr/ to get your region 2 Toshiba sd220e region free. It works great. This is what you need to do
    - Download the rar file at the link provided by Labman
    - Unpack it using WinRAR
    - Start Nero Burning ROM, click File, click Burn Image..., select the .cue file, click open, disable 'Determine maximum speed' and 'Simulation', at write method select Disc-at-once (this is very important), click write.
    - Push setup on the SD220e remote control, select under picture:
    PAL/Auto: Auto. Push setup again.
    - Open your SD220e disc tray and insert the CD.
    - Close the disc tray.
    - The disc will be read and recognised as a VCD, you'll see the image on
    your television flash and after a short while you will not see any image
    at all. Wait about 10 seconds and take out the CD.
    - Your player is now region free. Tested it with a region 1 DVD and it
    worked great."
  14. HitmanIP7
    HitmanIP7
    Jul 16, 2003
    789
    28
    UK
    +25
    Okay. Thanks for that :)
    Thats the one I keep finding though. The problem is that I have lost the option in the menu to change between PAL/AUTO.
  15. Unsure
    Unsure
    Where are you looking for the option? Without looking, I think when you press Menu, it is under picture.
  16. HitmanIP7
    HitmanIP7
    Jul 16, 2003
    789
    28
    UK
    +25
    Yeah, it used to be under the first item on the menu 'Picture' but its not there anymore.
    When I press zoom 6 0 6 zoom, it gives the info on the ROM version, etc. On there it says 'V-FORMAT: NTSC'. I think it should say PAL/NTSC.
    Im not sure whats caused this. The only thing is that for a while I was watching some region 0 DVD's, then when I went to watch a region 2 DVD is wouldn't work.
