Toshiba SD220E pure NTSC mode
Discussion in 'Blu-ray & DVD Players & Recorders' started by phuturephantasy, Jul 25, 2002.
  1. phuturephantasy
    phuturephantasy
    Is there a handset code to force the Toshiba SD-220E to output PURE NTSC?
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    If its like the Toshiba 210 just go into Setup and select NTSC. You should have the option of NTSC or PAL only. There´s no hack needed.
    *Sorry, quick edit, I should have said the option of AUTO or PAL. AUTO on R1 discs should give NTSC playback.
  3. phuturephantasy
    phuturephantasy
    On the SD-220E you have a choice of PAL/AUTO but I also have an SD-100 and that has a handset hack to force it to output PURE NTSC rather than the usual more uk tv friendly NTSC (not to sure was the actual technical name is for this type of signal, 3.58 rather than 4.43 I think)
  4. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    Can the 220 output Pal from NTSC DVDs so as to use it with an old TV which can't cope with NTSC?
  5. PeterL
    PeterL
    Apr 20, 2002
    112
    16
    Bournemouth
    I have an SD220 and would also be interested to know about a handset switch to output pure PAL. My old TV will play NTSC output from R1 discs, but squashes the picture into 4/5 the size.
    Can anyone help?
    Cheers, PeterL
