Toshiba sd220e multiregion no more
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by surferboya, Jul 27, 2004.
  1. surferboya
    surferboya
    I brought a multiregion Toshiba sd220e about two years ago, it has been great, playing R1 with no problems but two days ago it just stopped! Every time I put a R1 disc in it says there is a disc error, ie it is no longer multiregion. I have tried to download the firmware? update from various sources but the file seems to be corrupt (I can't get the cue file to work, it says there is an error in line 1?) I desperately need to find a working download of this or I may have to buy a new player. hopefully someone can help and get me out of this mess.
  2. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    I had a CD that contained the multi-region hack for this but gave it to my niece along with the h/w. I could retrieve it but it might take up to a week, if you can wait.
  3. surferboya
    surferboya
    Thanks for the offer but I have found a CD on the internet for about £6 and have already ordered it, will post if it works correctly. thanks again
  4. wokeye
    wokeye
    Apr 15, 2003
    658
    +63
    I sent you a PM, would of sent you a copy for nothing! Suppose £6 isn't much but I guess the guy is making a 2000% profit :rolleyes:
