Toshiba SD220E firmware anybody?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Mr Flibble, Sep 7, 2005.
  1. Mr Flibble
    Mr Flibble
    Does anybody know where I can locate the firmware to make this player multi-region?
    All the posts and web searches point to the 'chez' site for this firmware but this does not appear to exist anymore.
  2. mray
    mray
    Feb 16, 2004
    2,736
    83
    London
    +222
    Try videohelp.com
  3. sparkyspark
    sparkyspark
    Dec 4, 2002
    2
    Brentwood, Essex
    Let me know if you still need the multi-region upgrade and I will send it to you. :hiya:
  4. veedub66
    veedub66
    Hi Sparkyspark
    I would really like the multi-region hack/upgrade for Toshiba SD-220E DVD player if you could possibly send it to me at joynor@tiscali.co.uk
    Many thanks for your help
    regards
    veedub66
  5. veedub66
    veedub66
  6. mr spock
    mr spock
    Hi all i have a Toshiba SD-220E dvd and i need 2 make it multi region any 1 know how 2 do this.
    If any 1 has the multi-region hack/crack could u possibily send it to me at chrisncc1701@msn.com
    cheers
    Chris:)
  7. Ryderage
    Ryderage
    Feb 1, 2005
    72
  8. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    801
    46
    Maidstone, Kent
    +110
    :thumbsup:
    Just in case anybody is having problems downloading the firmware from the above site, try using a different browser. When I clicked on the Firmware button at the above site using IE6 nothing happened. I tried Netscape and the file downloaded OK.
    cheers
  9. ChrisFTO
    ChrisFTO
    Please somebody help me with my Toshiba to make it multi region. please email me at cphotiou@hotmail.com thanks:lease:
  10. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,174
    63
    Location location location
    +93
    ? Err, try reading the above posts! :rolleyes: :rotfl:
  11. quarry2006
    quarry2006
    Apr 24, 2006
    4,499
    +481
    I've had no problems downloading the hack (my player gave up playing multi region discs after a good three years' solid service), nor in unpacking it with Winrar.
    The problems I'm having is with burning the darned thing. I don't know whether it's because I'm using Nero 5 or what but when I get to the stage were you're supposed to click disc-at-once, the Nero window starts to flicker and I can't click on anything. Anyone know what I can do to get around this?
