toshiba sd220E + 5.1 audio output???
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dannykos, Mar 12, 2003.
  1. Dannykos
    Dannykos
    Feb 24, 2003
    39
    East Grinstead, UK
    not trying to be lazy - have been searching for a few hours now - trying to find a dvd player at the price and quality of the toshiba sd220e - but with dolby digital 5.1 audio outputs.
    anyone own or seen a player that they think meets this sort of spec??
    i'm connecting to a panny ae100 and currently also shopping for an amp too!
    thanks.
  2. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Well if you are shopping for an amp why would you need the 5.1 audio outputs? Get the amp then just use a digital cable from 220E to amp for sound.
  3. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    That wouldn't work - the amp just amplifies the signal, do do what you are talking about madelbrot you need a receiver that decodes the signal AND amplifies it.
    Most amps have 5.1 inputs that take an already decoded signal from the DVD player and then amplify them.
  4. fraggle
    fraggle
    Dec 11, 2002
    1,441
    Milton Keynes
    +29
    The Tosh 510E I'm selling has 5.1 outputs and plays DVD-A, only a few months old. See my post in the classifieds forum :)
  5. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Ok so I didn't read it properly:blush: but you could buy a receiver/amp instead of a amp;)
