Toshiba SD220 & RCE discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by IanStatham, Jun 30, 2002.
  1. IanStatham
    IanStatham
    Have recently bought a multi-region SD220 from Richer Sounds and been very impressed with picture, sound etc. However I also bought a R1 version of Ocean's Eleven from play.com and it will not work on this player. I have heard about RCE encoding and have read the recent thread on the bios updates for the SD220 but nobody has mentioned whether the multi-region 220 should handle RCE discs or not.
    My question is - Should the Tosh SD220 handle all R1 discs (including RCE) and secondly is R1 Ocean's Eleven RCE encoded?
    Thanks in anticipation
  2. Squirrel God
    Squirrel God
    Toshibas are a bit notorious for RCE titles.
    If your multi-region mod doesn't play RCE's automatically, there should be a workaround.
    Look here:
    http://www.techtronics.com/uk/shop/510-rce-toshiba-players.html
    http://www.techtronics.com/uk/shop/510-rce-regional-coding-enhancement.html (workarounds down the page)
    and try this (taken from second URL):
